Thio-Trine AKA Sodium Thiosulphate AKA Hypo ppm?
Aug 6, 2008
429
Honolulu
Question 1: Using the above product to neutralize chlorine at a rate of 1 oz for 1 ppm Cl per 10,000 gallons, how much sulphur in ppm is deposited in a 10,000 gallon pool per oz of Thio-Trine?
Question 1: Does this have any effect on algae either good or bad, or is it neutral, using say 7 oz?
Thanks for any help.
It doesn't matter. Sulfur isn't a particularly critical element for algae growth. As for the amount of sulfur added, that depends on the concentration of product -- there are many different reducing reactions that can occur with thiosulfate and chlorine so I can't tell what they are assuming. Sulfur is around 32 g/mole while chlorine is in units of around 71 g/mole -- if it takes 4 sulfur for every chlorine then for each 1 ppm FC you get rid of you will have 1.8 ppm sulfur; if it takes 1 sulfur for every 2 chlorine, then for each 1 ppm FC you get rid of you will have 0.2 ppm sulfur. The former is the more likely reaction, but dosing usually assumes less thiosulfate is required.
