I'm looking in to changing my pool from manual chlorine to a SWG. This is due to using a chlorinator with pucks as I have not been able to do the manual liquid chlorine due to a number of factors (some of them being just on my side that I don't want to do each day). So I think my best route to avoid high CYA each season is to switch to SWG.
High CYA started happening last season for me as I had a new vinyl liner put in the summer before. My new liner covers the steps, so the pool company recommends I do not drain the water for closing below returns so the liner does not get messed up (I used to drain below with the old liner). With draining that much each season, I was replacing almost half of my water each season (only 6 feet deep in deep end) and then when opening, CYA was zero. But now that I don't drain, the CYA remains over the winter and this year I am 100+ at opening.
So I have a few questions as I explore this. Does anyone have a recommendation for which SWG to use for my pool? Details are in the signature. I don't have a separate timer for the pump, as the new pump contains a timer built in. Can I wire the SWG to the pumps timer?
Also, what do I need to do before changing to SWG? As my CYA is high, do I need to replace water as well?
