LAST YEAR: Pool cover pump got SOME of the water off the cover... LOTS of leaves all over. Yeah, looked very much like the one shown on the article HERE
This one:
HAS to be a better way... Pool cover pump constantly clogged with leaves. Hmmmm.. .
So I took a plastic bucket with holes in the bottom, from some plant we bought, put a fine and then a coarser screen and jammed them in the bottom. Added the pool cover pump and a brick to sink it all... Added ropes from 2 sides so two people could position it where desired. Looked like this:
Then we positioned it in a likely place. Like this:
Umm. In THEORY the bucket would sink smoothly. In PRACTICE it tipped like this. But it kept the pump clean and pretty much submerged. Turn it on and... 5 hours later it looked like the above picture. A little raking and a little wind and sun and today it's ready to remove SMOOTHLY without a bunch of water and leaves as we try to get it over the end of the pool.
Worked For Me. And I've got that bucket saved for next year.
UPDATE: Removed the cover rolling it towards the end with the bucket/pump. Ended up with some water around the bucket but it emptied in about 1/2 hour. Then it was light and easy to pull last of cover with bucket inside it up over the edge. Nothing from the top of the cover got into the pool.
I had added 2 gals of 6% bleach around the edges yesterday. Today: The pool is CLEAR all the way to the bottom! About 40 leaves to vacuum up. Last year with quite a bit of water and leaves and sediment getting into the pool as we wrestled the cover off one end, it was pretty cloudy to start. This was VERY Worth It!
Filling now, all plugs / filter drain etc. ready to start up pump / filter when water is high enough. Reinstalled filter pressure gauge I removed last year (I had two gauges ruined over winter last 2 or 3 years).
If it wasn't for the pool temperature (44 F) I'd be tempted to dive in.
Regards, Terry King
...In The Woods In Vermont
The one who dies with the most Parts LOSES! WHAT DO YOU NEED??
This one:
Regards, Terry King
