RobHudson
I'm back. I blew from the pad with the cyclone. First the 2 wall skimmers, then put in antifreeze and gizmos. Blew out the main drain and air locked. Blew out the spa drain and air locked. For about 2 minutes after that, I heard an air hissing sound. I assume this means I have a leak somewhere?!?!?!?!?!?!?!? It stopped after about 2 minutes. I assume that means water had come into the line at that point.
I'm going to retry the main drain and spa drain. Not sure what I could be doing wrong, unless the seal on the valve is broken. I know that happened to one of the valves earlier in the year.
