Hello All,
This is the first season I am using what we would call a proper test kit (TF-100). I got it a few weeks ago when I found a combined chlorine issue. Thankfully that is now taken care of.
However, I suspect there is an issue with my kit with respect to TA and CH. Here is why:
I wanted to verify my CYA results as I know that is a test that a novice can easily misread. So i got my result and then tested the water in few "non recommended" ways to see if everything was in the ballpark. First TA:
The strips I have and 2 different stores (that test 2 different ways) all have my TA between 110-120. My TF-100 test continues to give me 170 after multiple tests. I am being meticulous in counting the drops and following the directions.
Now CH:
I normally dont worry about CH very much, but since bot stores and my strips had me between 125-150 and I happen to have some CH increaser at home, I added about 5.5 lbs to my 10,000 gallon pool, which should have gotten me to approx. 200. The TF-100 has me at 400 now! I know as you read this, you assume I must be doing the test wrong, but I assure you I am not. Could I have gotten a bad/old test?
I know 1 store or strip test vs the TF-100 would have me believe the TF-100 every time, but 3 different tests agree that the TF-100 is way off. I dont know how I can trust the FC or PH readings if the other tests are so far off!
thanks
Now CH:
thanks
