So I got my test today. It took 24 drops to get my TA test to stay a sort of reddish. That just doesn't seem right. Not sure how pink its supposed to be. Could use a little guidance.
Yep, full Barbie pink. Only other suggestion I have is to swirl long enough between drops as you get near the end.
For the test, you keep going until no further color change occurs, then don't count the last drop.
Here's the extended test kit directions for TA. You could try playing around with the low sensitivity test (10 ml sample, 1 drop = 25 ppm) which would give you a cross-check for your technique. Pool School - Total Alkalinity
