TF-100 CYA Test
Patrickoleary
169
Greensburg,PA
Any tips for the TF-100 CYA test? I tried the TF-100 and estimated 60. Tried my ColorQ and it told me 63. I wanted to get to 75 CYA, so I added some liquid stabilizer. I used Pool Math and tested the next day. The ColorQ told me 80. I thought I added less, but it will come down with dilution and splash out. I did the TF-100 and estimated 60 again. I'm not sure if I am doing something wrong or my mind thinks it sees the dot when it doesn't. Not sure.
Thoughts?
Here are my go-to tips ...
CYA Testing:
Proper lighting is critical for the CYA test, so you want to test for CYA outside on a bright sunny day. Use the mixing bottle to gently mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then gently mix again. Recommend standing outside with your back to the sun and the view tube in the shade of your body at waist level. Then, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. To help the eyes and prevent staring at the dot, some people find it better to pour & view in stages. Pour some solution into the viewing tube, look away, then look back again for the dot. Repeat as necessary until you feel the dot is gone. After the first CYA test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, gently shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate your own CYA reading. Finally, if you still doubt your own reading, have a friend do the test with you and compare results.
