- Sep 19, 2020
- 29
- Plaster
- Pentair Intellichlor IC-20
Pool has been pretty well balanced but PH creeps up to 8 (1-2 drops of R-0005 brings it to 7.6-7.8) and TA is kinda stuck around 100. Test logs are on pool math.
Questions:
For PH is ok to keep adding Muriatic acid every other week? Also, acid amounts called for differ on Pool math (4.5 oz) vs Taylor Chart (9.16 oz) I have been using the Taylor dosage.
TA should go down once PH is controlled, correct?
Also is it normal for the salt test to become like cottage cheese when adding the R-0718? Numbers come out correct but wondering if there is an issue with the liquids.
Thank you
Questions:
Thank you
