First off, I have a new Hot tub which came with a starter pack of chemicals (I intend to let them run the course before transitioning systems). The system I was provided with is the Frog @ ease (chlorine / mineral) based system along with a non-chlorine shock made by spagard. It also came with the tester strips from the frog product. I found it very difficult to read the tester strips and have ended up taking samples to my dealer during these first two weeks of ownership. Most numbers where off from my readings but within a reasonable order of magnitude. In the interim I order the Taylor K2006 testing kit for my own use. It finally arrived and I was anxious to test my own numbers accurately and balance my water properly. That said, the kit has my chlorine counts way out of line with both what I found on my test strips and what my dealer tested me at with his.
The test strips I was using don't give a hard number but rather a color to match with which, if the system is short your suppose to adjust it to dump more chlorine in unless the canister is spent of course, my tester showed a little lighter than the color. The ideal range of this system being between 0.5 and 1.5ppm FC. The store tested me 2x's now (1 wk apart) and both have been in the .5 to 1.0FC range. I tested 3x's today with the taylor kit, it seems like I'm having to use way to many drops (I have shaken the reagent before dripping completely vertical not tilted). I'm using the 25ml water sampling. I do two dippers of the R-0870, before I even swirl its fairly reddish, i swirl to mix. I add R-0871, while swirling it takes 36 drops(each test within in a few drops). By my count, this translates to an FC of 7.2ppm (Way higher than other tests). I add R-0003 while swirling to get it to start transitioning from the redish to clear takes 62 drops. This translates into 12.4ppm CC and 19.6ppm TC respectively. These numbers seem way off base to me compared to what it should be and what other test have shown. According to the kit my ideal range should be 2-4ppm FC and 0ppm CC, according to frog system its suppose to be between .5 and 1.5ppm based on its tests, store tests and its dispensing settings.
Other current figures as of today are as follows:
Water temp is 98deg F
TA is 120ppm
PH is 7.4
CH 200 ppm
I also checked the date codes of the reagents, R-0871 is the oldest with the earliest expiration being 9/21.
Any thoughts or ideas on what is going on with these results and why so many drips? Is there a means of testing the calibration of the reagents? I welcome your feedback and suggestions
-Stumped.
TA is 120ppm
PH is 7.4
CH 200 ppm
-Stumped.
