Hi all
Taylor k-2005
6/1/22 Before Clear balance (water cloudy, I haven’t been about to get clear all season )
20,000
FC- 7 ( added 2lbs 78%, evening before )
CC- .42
PH- 7.6
TA- 114
ALK adjusted- 102
CH- 212
Metals- 0 (pool store test result)
Sat. Index - .2
6/3/22
Cloudy water
Added 2 tabs chlorine
Added 2 tabs clear balance
Backwashed& vaccummed
6/6/22
After clear balance ( water crystal clear since 6/4/22)
DPD 10ml- .5
FC- 4.5
Cc- .5 (1drop to clear)
PH- 7.2
ALK - 90
ALH adjusted - 78.45
Sat. Rate - .-5 (ALK adjusted)
Sat rate- .3 ( TA)
All other result same
QUESTIONS
1. What is your experience with keeping water balanced with clear balance and do you recommend it?
I am giving clear balance the credit for clearing up my water, since nothing else has worked! I may be wrong, but have tried SLAM, Algicide and clarifier’s since the beginning of May.
2. Should I add about 1.5lbs PH up to change from 7.2- 7.4/7.5? ( TA would become about 98ish )
3. Or would you let the results from 6/6 be until PH/ TA gets below a certain number?
4. If left alone, at what numbers would you then add chemicals?
5. Any other advice or tips please add!
Thanks all
Taylor k-2005
20,000
CC- .42
PH- 7.6
TA- 114
ALK adjusted- 102
CH- 212
Sat. Index - .2
6/3/22
Cloudy water
6/6/22
DPD 10ml- .5
FC- 4.5
PH- 7.2
ALK - 90
Sat rate- .3 ( TA)
QUESTIONS
Thanks all
