I purchased a TDS meter and for testing my RO system, but then decided to test my pool with it. Just because I can
. Am I correct that TDS is the sum of Salt, CH, CYA and TA in ppm? It seems pretty close. Here are my readings:
TDS: 2100 ppm (using my TDS meter)
salt: 1500 ppm (using 0.5 conversion of the 3000 ppm showing on my Aquarite SWG)
CH: 320 ppm (Taylor test)
CYA: 60 (Taylor test)
TA: 80 (Taylor test)
Total of components are 1960 vs TDS reading of 2100. Given that there are probably some metals and other stuff in the water, this seems like a reasonable result. So is this the way the math works for TDS? Or do other components need to be adjusted the way Salt is adjusted?
This is purely for sake of curiosity.
