- Oct 6, 2023
- 4
- Plaster
- Pentair iChlor 30
Hi TFP! After years of planning, I'm finally ready to begin my DIY pool project, thanks in large part to this forum. I received the engineering drawing this morning, and to my surprise, I'm seeing larger pipe sizes than I expected for a pool that's barely 15,000 gallons. I'm attaching TDH worksheet here for advice. I was planning on running individual 2" lines for each of my suction components (two skimmers, main drains, and vacuum), as well as 2" pipe for each individual waterfall, bubblers, and a closed loop for all five returns. My question is, if I do it this way will I meet that "trunk and branches" spec, or am I forced to do what the worksheet says assuming I understood it correctly? If that's the case, what should be connected to those 3" and 2 1/2" pipes? Also should the pipes run all the way to the pump? Any advice is greatly appreciated, thank you in advance!
