Because you will lose some to sunlight and swimmers every day. You don't want FC to drop below the minimum before you next add. If you target 5 and in 24 hours you're at 2, then you need to target 6 instead. You'll just have to test and monitor things for a couple weeks to learn your pool's unique personality. The y key is to always stay above minimum.
