We recently purchased a house with an 27' above ground pool. We had to replace the pool do to wind damage. I am starting fresh with a new pool & water. I use the test strips & also just purchased a Taylor K-2006 test kit. I have verified that my TA is elevated with the test kit. I took a water sample to American Sale to have it tested & those results are below. They suggested adding 2 gallons of Muriatic acid. It lower the TA but not enough. I thought I was just given some bad information in regards to adding & running the pump.
TC - 1.1
FC - 1.1
PH - 7.9
TA - 220
CH - 325
Stabilizer - 30
I went back to American Sale & had my water tested again but I don't have the test sheet. They told me again that I would need to add 2 gallons of Muriatic Acid. They said to turn off the pump & dump it in around the pool. Let it sit for about an hour then run the pump for six hours. The TA is still testing high. On 6/17/17 I went to the Great Escape to have my water tested yet again & the results are below.
FC - .36
TC - .36
Cy - 8
pH - 7.4
CH - 391
TA - 195
They told me that these number were fine & to add two pounds of pool shock to get the chlorine number up. (Sodium Dichloro-s-triazinetrione, Dihydrate) Also to use a couple of stabilizer tabs in floater to get the elevated.
My test results from today are below that American Sale gave me.
TC - 2.2
FC - 2.0
pH - 7.5
TA - 195
CH - 325
Stabilizer - 15
They recommend two quarts of metal out they are telling me that the CH might be blocking the Muriatic acid from doing its job. I just need to guidance in getting my pool chemistry balanced. I don't want to keep dumping stuff into my pool & not achieve the desired result. One other thing to note, my water is crystal clear which is a good thing I guess.
TC - 1.1
FC - 1.1
PH - 7.9
TA - 220
CH - 325
Stabilizer - 30
FC - .36
TC - .36
Cy - 8
pH - 7.4
CH - 391
TA - 195
TC - 2.2
FC - 2.0
pH - 7.5
TA - 195
CH - 325
Stabilizer - 15
