Long story short about a year and a half ago approx found this forum and learnt a great deal and carried out the slam process. Everything was perfect then after a month or so pool had a leak! After getting so many people to come and have a look it is now finally repaired (for good I hope).
the pool was emptied and cleaned thoroughly and then refilled. I added stabilised chlorine granules 5ppm three times. And then I just left everything for a few days (went away due to work). Came back today and here are the results:
Ta 167
Cc 0.11
Fc 0.02
Cya 9
Ph 7.9
I don’t bother checking for water hardness as it’s very hard water and here and I can’t find a solution that is within something I can afford.
Question is Ta is quite highly but ph is only slightly high. I remember lowering the Ta last time and then aerating to increase ph but aeration seems to be more an art than science. Is it ok if I just bring ph down slightly and leave the Ta as it is? Poolmath is saying to add 201g of dry acid to reduce the Ta.
Please advise!
Ta 167
Cc 0.11
Fc 0.02
Cya 9
Ph 7.9
Please advise!
