Moved into our home last summer with 3 year old pool. Had a service do the chemicals for 6 months but they didn't give it much attention. Been doing PPP. Water is crystal clear. Took in a water sample to local Leslie's Store this am and most readings matched mine (using TF-100). But they had TA at 120 and I have it at 70. All the other levels match with mine. I drained the pools four months ago to get CYA from "infinity" (lol) down to 45. I cleaned the TF-100 vials and did the TA test three separate times and still come up with TA=70. TA for me has typically been 80-90 but has tested lower the last month.I test the water every day. Haven't had to slam it since I took over the chemicals. We have the waterfalls on during the day and PH tends to drift up about .1-.2 per day. So I am adding some acid about every 2-4 days to stay withing 7.4-7.8 and liquid chlorine every 2 days. Do I trust my TA readings over Leslie's? It just seems to be such a wide variance.
FC 3-7
pH 7.5
TA 70 (TF-100) or 120 (Leslie's) ???
CH 250
CYA 45
FC 3-7
pH 7.5
CH 250
CYA 45
