when I read the bromine sticky, it said you needed to SHOCK the tub: Here is a step by step: As you see on number 3, it says you can use bleach. Nowhere does it talk about fiberglass. So based on what I understood or misunderstood, I needed to keep the FC at 3-7/pH of 7.5-8 and TA between 70-90. We have bromine tabs in there. I am still very confused. I was just trying to check everything and get it right.
1) On each fill balance the water (adjust TA and pH. Add calcium if below 125 for acrylic spas or below 200 for plaster). More info here on balancing spa TA and PH, How do I use Chlorine in my Spa (or pool)?. If you have metals in your water add a metal sequesterant.
2) On each fill add sodium bromide to the water. (Follow manufacturer's directions on dosing. You will end up with about a 30 ppm concentration of sodium bromide.)
3) Shock with your preferred oxidizer (chlorine/bleach or MPS) and turn on the ozone if you are using it. Your bromine levels should now be above 10 ppm. Wait until they drop below 10 ppm before entering spa.
4) If using a 3-step system add your floater with bromine tabs and adjust it to maintain a 4-6 ppm bromine level. If using a 2-step system add your preferred oxidizer as needed (and adjust your ozone) to maintain a 4-6 ppm bromine level.
5) Shock weekly to burn off organics that collect in the water. (If you are using ozone and your bromine levels are staying at 4-6 ppm then you can shock less often.) Wait until the bromine level drops below 10 ppm before entering spa.
6) Test bromine and pH before entering spa each time. Test all water parameters (bromine, pH, TA, Calcium Hardness) weekly.
So I guess what I need is for someone to step by step tell me what I am doing wrong. I put everything as the very first line in my post about my spa so I wouldn't "waste" anyone's time as I had been reported to moderators. I don't know what else to say or to post. Just trying to understand.
