Following y'all recommendations, O have been using liquid chlorine and MA to balance FC and pH.
What I noticed that at TA of 100 and higher, my pH was rising quicker. So the higher my TA, the sooner I had to add more MA to water, to bring pH down.
After reading more on this relationship, I decided to bring TA down to 75, by adding MA (enough to bring pH down to low 7s). Them I would aerate water (aka turn on any water features I had), so air bubbles were going into pool to aerate it. This in turn brought my pH up, without affecting TA.
Once my TA reached 75, my pH ruse has stabilized. Last time I added MA was 5 days ago, and as of yesterday, my pH was still identical. Coincidentally, my FC also stayed same but I did increase chlorinator setting by one (from 4 to 5), while I am adding cya via tabs.
I'm sure you fine folks lnow this well already.
However here is my inquiry.
Without experimenting and watching trends, how could I have known what to do with TA? Is there someone known TA limit that one needs to go under to reach this balance? Or is it simply treat, observe, treat more, observe more, to eventual reaching this balance between TS and pH?
Wanted to understand this more than just "it worked, so just leave it alone" approach.
Thanks.
Thanks.
