Hello! I bought a new Bullfrog spa last summer and since I'm terrible at maintaining things I thought I'd stick with the frog system. We use the spa infrequently. My ex husband maintained our old spa with chemicals and in the past year I've discovered just how much better that was.
So, how do I switch now? Everything is unbalanced, the water is a little bit murky. I'm reading the posts "How do I use Chlorine in my Spa (or pool)?" and "Cyanuric Acid and Free Chlorine Levels". I just bought the drop test kit recommended and am about to order Ahhsome.
I expect I'll be draining and refilling. And I found a step by step in this post First Time Bullfrog Owner - Need help with Frog Ease System. Is this good? I read that I don't need to fix the water BEFORE putting inthe Ahhsome for the first time. I think I understand that step 1b is drain the tub? And hopefully I wouldn't have to do it again (I live in the desert with drought & water restrictions). I'm guessing I'll have to do this over a weekend; it sounds time consuming. Any tips for the purge cleaning?
1) Purge With Ahhsome
2) Fill tub
3) Adjust pH with Muriatic Acid and bring CL to shock level with DiChlor
4) Keep using DiChlor for CL until I get to 30 ppm of CYA
5) Switch to bleach
6) I check my TA, CL, and pH. Takes about a week to get the TA/pH dialed in, and then it is stable.
7) I use AquaClarity once a week
8) I add Cl (bleach) once a day, and then again if I use the tub.
9) I check pH often, but only because with a meter, it takes about 5 seconds.
