Moved from old thread HERE
I don’t know how current this comment is but we went thru the same. Finally read where getting rid of your DE filter and changing to the sand filter unit and using the glassine filter . ALL of our problems were solved!!! I hope it isn’t too late and you still have it. My dau-in-laws love swimming, says it leaves their skin so soft.This is my 4th summer with my pool. When I had it built the dealer recommended Ecosmarte for a wonderful Non-Chemical pool. However he failed to tell me that I would have to put in 10x the amount of work as my neighbor who was going to use chlorine in his new pool.
Over the past 4 years I have made several calls to Ecosmarte each summer and their staff is always helpful. I have experienced several issues over the years and thought I finally had a handle on everything his year. WRONG!
For the second time this summer I have uncontrollable algae. This past weekend brushed the entire pool and took apart my DE filter and cleaned what looked like an alien life form growing inside off the grids. I dumped 50oz of Algaecide 60 in the pool and added 8lbs of non-chlorine oxidizing shock to the pool. I came home from work today to see the algae coming back.
I am beside myself. I don't know what to do Any advice? Should I switch to Salt? Chlorine? Change to a sand or cartridge filter??
I was thinking of putting Metal Out in the pool and just using chlorine for the rest of the season (and dumping in a whole lot of shock) and next year switching to a salt generator and a cartridge filter.
My Levels
Calcuim 400
PH very low under 6.5 (ok per ecosmarte)
Copper is 1.0 ppm
FYI
After 4 years in my opinion here's the pros & cons of Ecosmarte in case anyone is considering using it (not including any of the chemistry debate)
Pros:
No Chlorine.
Getting to be known as the "copper guy" at the local Leslie's
Not having to worry about Alkalinity
Cons:
Can't use my Polaris (Pool must be brushed & vacuumed weekly to remove microscopic dirt that Algae eat)
If I miss a week I will have algae
Lots of money in Algaecide 60
Lots of money in Non-Chlorine shock
Lots of money in Phos-free
Can not "shock" the pool if Algae is present
Killing 2 hours every Sat Morning with all of the above
Water smells if PH is too low
Water always smells like algaecide
Again any advice is welcome. Thank You.
