Swimpure panel reads % output, not salt
AL-0 is AquaRite.
AL-1 NatureSoft.
AL-2 MineralSprings.
AL-3 SmartPure.
AL-4 This changes the default display from average salt to percent output.
AL-5 This is used with Jandy automation.
AL-6 means regular Aquatrol with a flow switch.
AL-7 means AquaTrol RJ (Return Jet with no flow switch).
AL-6 and AL-7 are used on the AquaTrol, which is an AquaRite with a timer for above ground pools.
AquaRite, Naturesoft, Mineral Springs and Smartpure are essentially the same unit with different branding. Hayward does private labels for certain companies. Al-0 to al-3 are basically equivalent other than a superficial name change. AL-4 is not about the name, it just changes the default display. AL-5 needs to be selected for the Jandy automation to control the unit properly.
Pressing the diagnostic button sequentially will display:
Default salt display
Pool temp
Cell Voltage - When not generating, the voltage is about 30 to 32 volts dc. When generating, the voltage drops about 1 volt per amp of current.
Cell current
Desired output (% of the knob)
Instant salinity
Product name
Software revision (r.XX)
Cell type
Basic AquaRite Diagnostics.​
This is the basic information we need to know in diagnosing a problem:
  • Report all diagnostic readings when you..
    • Move the switch from auto to off and check all of the readings.
    • Move the switch back to auto and recheck the readings.
    • Move the switch to off for a minute and then back to auto and recheck the readings.
  • What are the first seven characters of the cell and box serial numbers?
  • What is the actual salinity and how are you measuring it?
All of our content is free of advertisements.
Please consider donating at:
Got the panel reset to read English, cleared the salt reading, and cleaned the salt cell. System reads 2900. We had to leave town for a couple of weeks so I haven't been able to do a complete update - apologies for the slow response. Back home next week so will continue then.
Reactions: JamesW
