I am in the process of bringing up my SWG and running some experiments. Yesterday, in the 2nd day of operation, my SWG flow switch locked ON (closed position).
What I found was a tiny 1/2" length of "like a pine needle" had wedged itself into the location shown by the red arrow in the picture below. This is NOT the exact same flow switch in use on my Circupool RJ60+ but it gives a pretty good idea of what happened. This tiny needle prevented the switch from opening up all the way when there is no flow. Because I am in the midst of doing some pump testing, the SWG continued to produce chlorine/hydrogen while there was no flow in the pipe. I wasn't actually testing for a flow switch failure (I didn't expect it) and was lucky to catch it when I saw the gas was collecting and bubbling inside the SWG cell even though the pump had stopped.
Anyway, just last week I cleaned my filter so that needle might have been slowly making its way through the filter. It's also possible that I finally have to replace my cartridges after 8 years because there might be some spots that have opened up between the input/output, in particular I am worried about the seam where the paper filters are wrapped around and then glued together? Don't know how I could check that. Any thoughts on that?
Needless to say, I am a bit nervous about relying on the flow switch as the only backup to indicate flow is occurring in the system...my ECOStar pump is a bit past its expected failure date, haha. Any other threads where this occurred? Thanks!
