Hi all, I finally got our pool going, it took me a bit to re-level, hard plumb, and get everything setup. I did see some people with similar issues, but I am not sure what my options will be.
when I run my pump on the low speed setting, after 30minutes, I get a large bubble in my swg. When on high, it clears it out. It is from the swg. I am using 2” pvc, I have the swg lower then the pool level, below the sand filter and the heater is also at higher level. Is there a way to still run my pump at the low speeds? Or will I need to just let it run at high? here is a few pics. These where taken before I had the swg running. Thanks for any input. When I ran the old intex swg, I didn’t pay much attention to anything, just ran it. Now I am learning all the fine details of pool stuff.
