Ok, so I think I may have screwed up (or at least am getting ready to). After a long battle of leaks that I think I finally solved (all three drain plugs had pencil eraser sized holes on the outside of the fittings) I decided to try and get the pool up and running and am going through the SLAM process and figured it may be easier to convert to SWG. So, I just bought a 40k Circupool SWG (yes I am aware of some of the sketchy reviews) off Amazon. Unfortunately I decided to do some additional research afterwards and saw that it's recommended (strongly - is the part I missed) that a SWG rating should be double the size of the pool. Problem: My pool is a 32k gallon... but I can not find a 60k gallon rated SWG.... which is why I bought the biggest one I could find (40k).
Questions:
1. Does anyone make a 60k SWG - I've looked on Amazon, In the Swim and a couple other sites and the biggest I can find is 40k.
2. Is a 40k gallon sized SWG's ample for a 32k gallon pool? Just increase the run time?
I think I answered the rest of my questions through the search... I may do a thread on the install and update it over time with results, if anyone thinks it'll be of benefit to the site.
Flame suit on for buying first and researching second.
Questions:
