I'm considering a SWG and have focused on the RJ60. However, my wiring setup has me concerned. The pump is really far from the house so I suffer from a fairly large voltage drop. With the pump running the voltage drops from 123 to about 113 to 114. I'm concerned that adding a SWG will cause an even greater voltage drop and cause the motor to run hot.
Would anyone with a 115V setup and a similar sized SWG be able to tell me what kind of voltage drop you experience?
