So I’m on the edge of whether to add the Ichlor30 for my small pool. I have gone through numerous threads and maybe just need some final encouragement…
1. Is my pool too small to even consider a SWG …..My CYA of 90 and extreme daily burn off of FC makes me have to keep my upper level at 13-14 FC to not drop below min level. Adding the SWG seems like a huge plus for mitigating daily liquid chlorine additions but want to make sure I’m not complaining about my small pool daily maintenance compared to other larger and more demanding pools lol.
2. If you go on vacation do you adjust the SWG to a slightly higher level for a week to ensure proper FC while away? … in a sense to mitigate any extreme weather or potential drop. Just curious how others handle that.
3. I know all pools have salt, but does the type of pool you have lend itself to be better suited for SWG? I have the aqua sport (aluminum body) buried 2.5 ft. I have read all the corrosion threads and if you properly balance it won’t be an issue…. But Is that absolutely true regarding all gaskets, o rings etc etc around the pool. Does the small
Increase in salinity impact anything?
Bottom line is I’m hesitant, more likely I way overthink things…just don’t want to make a wrong decision and what I thought would provide easier maintenance ends up shortening the life cycle of other things.
Appreciate the feedback
