- Apr 8, 2024
- 4
- Plaster
- Hayward Aqua Rite (T-9)
As a bit of background, since I don't know what will help: My pool was built last year, and the builder initially installed the wrong equipment (i.e., a salt system was specified, but they installed a chlorine system). So, after the season ended last November, and the pool was closed, the builder came and installed the SWG (they did leave the chlorine dispenser in place). Since the pool was closed when they did this, I wasn't aware that they had not programmed the Omnilogic controller, so I had to do that myself when I opened the pool last week. As far as I can tell, I got everything programmed correctly...the pump works, lights work, everything is going fine. However, the SWG doesn't seem to do anything. I've watched it for days, and the instant salt reading is always 0 PPM. After reading various SWG-related posts here on TFP, I thought it was because the water temp had been too cold (under 60 degrees), but today the water got to 70 and I still get no instant salt reading on from the SWG. I set it to run 100% of the time, no change. Currently, the readings are:
cell temp range: 50-120 F
Cell temp: 70.1 F
instant salt: 0 ppm
average salt: 2800 PPM (this mystifies me, because it's never given an instant reading, and as I understand the average reading is just the average of instant readings)
salt monitoring: standard
cell type: T-Cell-9
cell voltage: 34.52 V
cell current: 0.00 A
Board temp: 79.1 F
relay polarity: OFF
So, I feel like the programming is okay because the diagnostics are showing the water temp and voltage to the SWG, but there's no cell current and never any instant salt reading. It does show an average salt reading, but I also tried unplugging the unit, and re-programming the controller, and the average salt reading didn't change (I expected it to go to 0...but that was a guess on my part).
I'm not sure what to do from here. Any suggestions as to where I go from here? This is my first pool, and I really have no idea what I'm doing
Cell temp: 70.1 F
instant salt: 0 ppm
cell type: T-Cell-9
Board temp: 79.1 F
relay polarity: OFF
