Opening was painless this year. Water is balancing and behaving as I would expect based on my results last year. Current results:
FC = 3
CC = < 0.5
PH 7.6
TA 110
CYA 40
CH 425
My question is this. Last year I ran my SWG at around 10% with the pump running full time at 50 GPM. I routinely had FC readings around 6 or 7. I could easily take FC up to near slam levels at full production and leaving the cover closed during daylight. This year I’ve got the SWG running at 100% with pump at 50 GPM 24 hrs and I’m not breaking 3 to 3.5 FC. Admittedly my CYA is down a bit and I’ve got 4 lbs going in the pool this evening via sock/return.
The pool was finished in July of last year when temps were already hot. I assume, since the SWG won’t produce if it’s too cold, that there is an efficiency effect on chlorine production based on water temp, which today was up to 77 or so. Temps last year temps were typically 84 to 88. Can the lower temps be having that large of an effect on chlorine production in the SWG or is there something else going on I should be concerned with?
FC = 3
CC = < 0.5
PH 7.6
TA 110
CYA 40
CH 425
