I want to do a solar project for long term power outages but I would also like it to be some use year round. The perfect place is for pool filtration because I can directly run a pump from the solar panels without the need to store a lot of power in batteries, large inverters, etc.. I JUST got a new variable speed pool pump and going 100% solar is expensive so I do not want to go there.
What I would LIKE to do is build a small waterfall / fountain at the shallow end of the pool, run a DC pool pump 12v or 24v that just operates the waterfall when the sun is out, with a small basic cartridge filter. This would give some filtration in long term power outages and also allow me to run the main pump less.
Looking for DC pumps is difficult because there are just so many out there and none that I find are good choices for this project. They are either too small rinky-dink 1gph $15 pumps or $400 to $1000 pumps. I would like something in the $100-$200 range. This will not be used to clean the pool, I can use the main pump when I need more power. I assume I need some sort of self priming pump since I do not want a submersible in the pool all the time.
Any suggestions on where and what to look for? Has anyone else done anything like this?
In-ground ~20,000 gallon.
