Hello,
I’m really just looking for a sanity check. We just filled our pool after having it resurfaced with pebble sheen. Due to the recent extreme cold we’ve had in Texas my pool sat empty for about a month. After filling and getting the chemicals set up I noticed that the returns were pushing small bubbles out.
Having my pool empty for empty for that long I am paranoid that something shifted in the plumbing underground and cause a leak. However I think I ruled this out by using valve in front of the pump. When shutting off either the skimmers or the main drain once the pump primes it immediately starts gathering air bubbles.
So am I correct in assuming it’s after either the main drain and skimmer plumbing?
I’ve cleaned off the pump lid o ring and re lubed. I’ve cleaned, re-lubed, and tightened the inlet junction on the pump. Re lubed the drain plugs. Really the only thing left is the jandy valve.
Is my logic sound? I’ll be changing the o rings on the jandy valve as soon as I can regardless because they probably need it anyway.
Thanks!
Thanks!
