Happy Spring!
Hope all of you are well!
I've searched on the forum for over an hour for an answer to my problem but I'm giving up.
I found air bubbles coming from return in deep in yesterday and pressure gauge was down from norm of 13 to 10psi.
Pump basket lid has some cracks around the edge so was chief suspect.
I got a new lid, gasket and per the pool store, lube for the gasket.
After all was put on and restarted, pressure was back up to 15 and bubbles from return were minimal.
I backwashed and no bubbles from return.
This morning, I have tiny bubbles from return in the deep. I think the water in the pump basket is okay.
The pressure however is 11psi compared to my norm of 13.
A few things:
I don't know if I lubricated the gasket correctly. I put lube on both sides just enough to make it shiny and slick. Not a glob or thick at all.
Am I supposed to wet the gasket before closing it too?
There was a lot of debris in the back basket which accumulates frequently due to oaks around the pool this spring and lots of wind recently.
After cleaning the basket and compartment very well, upon restart debris came into the basket as if there was a good bit in the line. This was small leaves as well as the tassels from oaks.
Most likely a separate issue, I'm seeing sand on the pool floor along with some small dark debris. I did a sand change year before last so I shouldn't have channeling should I? Broken lateral?
I'm hoping I need to readjust the gasket on the pump basket for the air leak situation. Hopefully I don't know how to lube a gasket.
Thank you,
Joan
A few things:
Thank you,
Joan
