- May 23, 2015
- 25,695
- Plaster
- Pentair Intellichlor IC-60
I really think it’s a variable speed pump thing. I’m not in anyway a hydraulics expert (I’ll leave that to @mas985 and @JamesW ) but it has something to do with low pump speeds and where the pump is positioned relative to the water line. You can spend all day slathering silicone on every joint and seal and the bubbles will still show up.
All I know is I don’t have a leak in the pump because if I did the strainer pot would drain back into the pool. When the pump is off, there’s a small volume of air at the top of the lid and the level of water inside the pump pot never changes over the night time period when the pump is off (8 hours).
Just ignore as best you can. And if the voices in your head tell you to do weird things just put your fingers in your ears and run around screaming with your eyes closed … they eventually stop.
