So I have my vacuum hooked up to my only skimmer directly into the suction line. I think I should get a skimmer/vacuum basket combo so my skimmer catches debris floating…? When my pump is running I have my valve from the pool sucking as much as it can before the psi. Drops on the filter and the rest sucks from the spa. I feel like I am pulling more water from the spa and not filtering as much from the pool which I would think would be overkill to keep filtering the spa water let’s say a guess of 40% pool and 60% spa filtering. I could remove the vacuum and have the diverted that goes in the skimmer suck from the main drain a lot more and have the skimmer be more effective, but lose the vacuum for all the debris from storms, dust blowing, etc.
As far as the returns, I have 2 in the pool and 2 in the spa. I have it return to the pool as much as possible before the psi. Goes up and the rest returned to the spa.
From the picture you can see in floor cleaning, but I don’t use them unless heating the pool.
Question-
Any advise is appreciated
Should I use the infloor as returns (they are worn out and provide no action in moving debris around on the floor)? But could return more water to pool with out having psi. Increase.
On the return jets, what is the best position-up, down, toward skimmer,away from skimmer?
Thanks
Question-
Thanks
