Ok, numbers..
CYA- 60
CH-250
TA- 60
CC-0
FC- 8
Everything is great, pool looks wonderful
I left one number off because...
PH 8.4
Was 7.5 last week, got about 6 inches of rain (cause of a gutter as well as rain) really about 3 inches of rain, in the pool the last 2 days. but... this isn't the first time it happened. PH just jumps like crazy all the time.
No aeration at all anywhere on the pool, no pumps no slide water running into it or anything.
I have dumped so much Muratic acid in the thing this last month to get the TA down from 100, to 60 and cause the PH jumps almost .8 points in a week. did the same when it was 90's does the same if it doesn't rain, rains, doesn't matter.
any ideas? I am quite sure after today the TA will be around 50, and the PH will be back down to 7.5 with half a gallon of muratic acid i added this morning. Is this just a fluke thing? Maybe the sand filter is adding lots of air that i can't see?
PS... I guess the rain could have done it, splashing and all, but it does it with or without the rain, and the rain is PH 7.0 ish, I tested it once a month ago or so
Thanks.
CYA- 60
CH-250
TA- 60
CC-0
FC- 8
PH 8.4
Thanks.
