- Apr 24, 2021
- 43
- Vinyl
- CircuPool RJ-60 Plus
Hello! I am opening the pool for its 2nd ever season, and i think i am doing something incorrectly with the filter/pump. (My equipment specs are in my signature, salt water system NOT installed yet, so just sand filter and pump.) The filter stay outside all winter drained and opened, and the pump came inside and spend the winter in the basement.
To get started this year, i hooked everything up, closed the filter drain, primed the pump and put the filter on "backwash". I turned on the pump, and that went fine.
Then:
I unplugged the pump, and put the filter on "filter."
I now have great suction and flow, but there are tiny bubbles in the outflow visible on the surface of the pool, and the filter pressure has never once budged off zero, and the pump basket window has bubbles too. The filter gradualy looses its water level, and then the view glass ends up empty, until i do another backwash to fill everything back up.
At one point the breaker tripped, but has stayed on since being reset.
Am i skipping something important? Do i perhaps have a leak, either water or air -- and does anything i've said indicate where it would likely be? Or do i (also?) have a broken pressure gauge? I don't see an air relief valve, and read in another thread that not all haywards have them, so it must be something else.
Thanks for any suggestions!
Then:
