One of the plugs on my Hayward pump (the one that almost sits on the ground opposite the pump) is stripped and there is a slow leak coming from this plug.
Any ideas on how to remove the plug? I have a replacement plug with the small o-ring and some lube.
I had to replace my Tagelus filter with a Hayward S244S. The flow rating for both is 62GPM. With the Hayward filter, the shallow returns flow is weaker. When I adjust the valve, the flow becomes only a bit stronger but then the deep returns stop flowing. Is it more important that the deep returns flow normally and let the shallow returns flow with less power?
Duraleigh Dave, mentioned this Hayward filter may be too small in a different thread. Is that it? There were no issues with the flow returns in my old filter.
