I just put in my pool/spa recently, and before closing it up for the winter, the installer said it was fine to fire up the spa. Since it is getting freezing here overnight, I have the automation set up with freeze protection, to keep everything flowing. Now that there is water in the spa jet lines, I added the jet pump to the freeze protect program, but something about my plumbing seems to be very strange.
Prior to turning on the spa, the pool was set up to pull water from the skimmers and main pool drain on the input side, and output evenly to the spa and the pool return lines (so that clean water would enter the spa, and then overflow into the pool). The only thing that is changed now is that the spa jet pump comes on as well (it is a separate pump, with a separate set of lines that pull from the spa drain and return back to the spa); the first morning after I set this up I discovered that the spa was drained by a couple of feet. Now, the only way I can keep the spa from draining when the jet pump is on is for the main pool pump to only pull from the skimmers and pool drain, and return ALL of the water to the spa return lines. If the return valve is even a little bit open to the main pool lines, the spa drains down. It seems that somehow the spa jet pump is causing the return water from my main pump to only go to the pool.
Not sure how well I am explaining this, but not sure how this would happen; as far as I know, the spa pump/circuit is totally separate from the pool filter circuit.
