I've been having some strange growths along the sides and floor of my pool, which I'm assuming to be gunite.
More recently: An algae-like substance, that takes a lot more work to scrub off than the usual buildup during SLAMing, which I just completed a few days ago. It's also more brown. I rubbed it with a lime, which had some effect but didn't take it all off. I wouldn't say the results were much more of an improvement over some hard brushing. If I could correlate some event to it, maybe it's after I added a phosphate inhibitor (phos-free type of Leslie's chemical) but that's all I can think of. The phos-free was pretty old, and had sat outside, though not in direct sunlight.
Overall for the past year or year and a half: Small dots (but all over the pool) of these very, very hard deposits of what look to be calcium (silicate?). They are very hard to remove. Is this going to require a scaling chemical solution or am I going to need to chisel them off? It wasn't always like this in my pool. Not sure what is changing in the chemistry. We did have a massive drought a couple years ago and then a massive few months of rain, enough to fill up all the lakes again. Possible issue there?
I will note that I did drain the pool a year ago and left it empty for a bit longer than I'd liked to. It did put some emphasized cracking on some cracks that had already developed. Those cracked locations began to develop a white substance that is similar in color to these hard deposits. Is this indicative of a pretty serious underlying issue? My pool is not losing water.
I am in D/FW, TX. I am fairly new to these pool forums, so forgive me omitting any pertinent information or any ignorance.
Pool Test:
TDS: 500
Copper/Iron: untested
pH: 7.8
Alk: 80
Free/Total Chlorine: 0/0 (just cleared up the pool and added phos-free, which requires low chlorine to my understanding)
CH: 220
CYA: 0
Phosphate: 0
I will post an image of the cracks once I figure out how to make it allow further attachments.
Pool Test:
TDS: 500
pH: 7.8
Alk: 80
CH: 220
CYA: 0
Phosphate: 0
