Still green water
Lidstromthegreat
4
Hazlet N.J.
I opened my pool last week and used liquid shock... started getting blue but the turned green again over night... shocked it hard again....Now I have super high chlorine levels and still green water..(I can clearly see to the bottom) I have low pH and alkaline as well as cyuratic levels... will adding the cyuratic powder finally get the water turning blue? Never had this problem before!!!
Okay. If you didn't know, test strips are horrible. Not sure why they even sell them. You need a reliable test kit at home. We recommend either the TF-100 or Taylor K-2006C. Either one, but you need it to be sure of those levels. From there, we can help you.
For now, add about 5ppm worth of liquid chlorine to the pool each day. Use the PoolMath app to help you with amounts. It's a great tool.
