So on my new pool I am looking to install a Stenner pump. But I am torn how to mount it.
I live in Arizona, and our houses are generally all stucco. Under the stucco is foam, followed by 1/2" plywood. The thing I am worried about is installing it against the house and is possiability leaking at some point (and chlorine running along the stucco and wrecking it.
Any ideas of other ways to mount it? Flat Steel Stock? Drive a pressure treated pole into the ground next to the barrel maybe?
