Today, upon inspection of my Stenner pump, model 45MPHP10 used for 10% chlorine injection, I noticed that the #2 tube has split. I also noticed that the Stenner check-valve (threaded to pool plumbing) was completely caked up with chlorine salts. This may be just due to the solution drying up since there was no flow. The pump has been installed and in operation since October 2016. Is this typical? Seems like the tube did not last long at all!
The pump is covered by the Stenner rubber/vinyl cover and also the rain hood. Sunlight exposure is thereby limited, but it could be better. Here in AZ, the sun is hot, and perhaps the temperatures and the sunlight made the tube stiff. However, even the brand new tube (included with a Stenner pump purchase) is stiff as well. It is a pretty thick-walled tube after all. However, the rest of the pump and assembly remains in great shape. The pump only runs 20 minutes a day in the morning when it's much cooler.
Just wanted to see what you guys think. Should the tube last longer? If not, then I must buy a box of them and keep them on hand! The Stenner automation is convenient, if it does not fail, but if tube replacement must proactively occur every 6 months, then it's NOT very cost-effective.
I should also note that I use the 10% chlorine solution from Lowes or Home Depot. I buy this because it's convenient for me, despite maybe not getting the best price per oz of chlorine. However, if it's known to be garbage (i.e. having too much salt, etc.), then I will discontinue using it and find another method, such as carboys from the pool store.
Thanks!
Thanks!
