I am nearly complete on my Stenner pump install. Everything is setup, but I am waiting on my electrician to install a 220V outlet powered only when the filter pump is running. I removed my temporary plug from my 2" x 2" x 1/2" FPT slip fitting and installed the check valve to see if would stop the water flow and essentially work as a plug until the pump was operational. When the filter was running the check valve would spurt water from the back onto the pad. I turned the filter pump off, connected the 1/4" black hose and put the other end of the hose into an empty bleach bottle to see if the line was needed for the check valve to work. The result was that the bleach bottle slowly filled up with water spurting through the line. I have reinstalled my 1/2" plug until the electrical work has been completed.
With the way that this pump will be setup, the Stenner pump will always be running when the the filter pump is running, so I am assuming that that 100psi from the Stenner pump should eliminate this problem. I disassembled and ensured the check valve was put together correctly and did not notice any defects. Is this how the check valve should work or is it something that I can fix?
