Our steel wall vinyl liner IG pool is 3 years old this month. We started to feel bumps under the liner last year in a roughly 2x2 area which starts just below the water line. Late this season I noticed the area had grown to almost a whole wall panel and started on another one across the pool. We contacted the builder and they suspected it could be rusting under the liner but would wait until closing to lower the water level and look behind the liner. They also contacted the manufacturer, Cardinal Pool Products who sent a rep out to inspect it. They came on Monday to close the pool and inspect behind the liner, but because the weather was cold they could only remove the liner in a small area, which was not the most affected spot. Well the Cardinal rep also came to inspect the wall issue and confirmed it was "white rust" or galvanic corrosion. He had no explanation as to the cause but suggested it could be stray ground current after he visually inspected the bonding at the equipment pad. Of course they just care about the panels and will repair the affected panels by scraping/grinding and applying an epoxy coating. As expected he said it would be up to the builder to determine if the liner can be dropped and reused. If not I guess it will be on us to pay for a new one. We are in the early stages of this battle and are waiting for his written report before we start the back and forth with the builder. Just wondering if anyone had any insights as to what might cause this and what repair options from the manufacturer I should except or demand for the best longevity. Pretty discouraging to have spent this much money on something I thought would last a long time only to start to fail so quickly.
