I have recently noticed small amounts of algae at the bottom of an indoor bromine pool. This is an association pool which I help to maintain. The pool company says they add algaecide, clarifier, phosphate remover and shock weekly. They shock the pool using potassium monopersulfate. All these chemicals seem unnecessary to me (following TFP protocols). Can I just use liquid chlorine to shock the pool and will that effectively address the algae issue?
Would there be any issue with people entering the pool shortly after shocking (with the high sanitizer level). Pool is clear other than the small amounts of algae I'm noticing in the corners of the pool.
Thanks for any help you can provide.
