It seems to me that the FAS/DPD test precision and accuracy is only absolutely necessary to determine when to end a SLAM (perform the overnight FC loss test, aka "OCLT"). However, while waiting for deliver of your FAS/DPD test kit, a simple OTO "yellow" test and an "overkill" use of LC can get your SLAM started. At least it did for me.
My wife and I recently bought an old homestead with a pool that had been closed at the end of summer four years ago. When I uncovered the pool and began the pool opening process, I was met by a swamp, plumbing leaks, and a faulty 220V line to the pump (a short in the underground conduit
). After two or three days waiting on the electrical to run the pump, I had the pool bottom almost free of coarse debris, but by then an algae bloom was in full swing. I clearly could not wait for the arrival of the TF-100 test kit I'd ordered to get started so I SLAMmED the pool without it and kept SLAMming until the test kit arrived.
According to the last commercial pool maintenance company log summary of four years ago (shortly before the pool was last closed), the CYA reading was 30 ppm, so I targeted 12 ppm for FC, per the SLAM guidelines. After a few days, I found that the sun of the day nearly zeroed out the pool TC, whereas little very little FC was lost at night so I began to suspect that the CYA was much lower than the last test result (which was confirmed later by my TF-100 kit and a reading well under the 20 ppm lower limit of the kit).
While waiting for the kit, I got pretty good at "cheating" without a DPD kit by matching the first OTO test yellow hue quickly with a kit that came with the pool. In order to extend the range of the OTO test to 15 ppm, I used a simple method. Before testing, I filled a beaker with four industrial syringes worth of our well water (very soft and obviously no CL) and then added one syringe full from the pool, mixed the water and filled the OTO test kit cylinder from the beaker. Then I multiplied the OTO test result by 5 to compensate for the diluted sample.
In one week's time, I went through 35 gallons of LC (25 Wally World 6% jugs and 5 Kmart KemTek 10% jugs). By the time my TF-100 kit arrived with the XL option, I didn't need the extra FAS-DPD reagents in the XL option. On the first night, the pool passed the FAS-DPD OCLT and I ended the SLAM!
So based on my experience, one doesn't need the excellent TF-100 kit to get started with a swamp cleanup, but the kit's precision is certainly necessary to determine when to end the SLAM. Just my $0.02 here, of course.
