I have dark areas all over the pool (the majority of the pool, ranging from greenish brown to black)--they start about a foot down from the top edge in the shallow end, a couple of feet down from the top in the deep end, and then randomly on the floor, stairs, and steps in the deep end. It doesn't go away with brushing (I have a wall whale, so I'm getting lots of pressure). It doesn't feel like anything (ie, it doesn't feel slimy).  Is it safe to assume that it's staining from metal-based products in the past or some sort of treatment that was applied to the Pebble Tec? How can I be sure? Is there anything else it could be? Do I need to get a professional to come out and look at it? I just want to be sure that it's safe to go in there once the test results are in range.
Â
Here's the history in brief:Â I have been fighting algae since I bought the house in December (never been swimming in it
). Gave up for awhile and let the frogs live in my backyard swamp. Finally found this site and am getting it cleared. Currently, it looks pretty clear until I brush (which I am doing 1-2x per day). I am maintaining at shock level (consistently since I got my test kit on Monday) because I am assuming that the cloudy stuff I am brushing is dead algae. The pump has been running 24/7 for about 2 weeks. The pressure is only about 2 over starting pressure. I drained a couple of feet this weekend because the last pool store test results showed I had a CYA of 100-141. I switched from pucks and cal-hypo about 1 1/2 weeks ago and now am only using 6% bleach.
Â
With my Taylor k-2006,
FC: 13.5 last night, added 50 oz 6% bleach to bring up to 15*. Did NOT test 30 min after adding chemicals. This morning before the sun hit it, FC was 15. I added 142 oz of bleach to make sure that it stayed at shock level throughout the day, but still below "high shock" of 24. I will perform the overnight FC loss test tonight/tomorrow if possible (actually, is there any point in doing that if I'm still getting cloudy stuff off the bottom and sides when I brush?).
CC: < or = .5 this morning
TA: 110
CH: 330/340
CYA: 40
pH: 7.5/7.6
Â
*Note: I am having some issues estimating the volume of my pool--I had been assuming it was 17,000, now I am assuming it is 16,000. It's an irregular shape, so I took several measurements and used the TFP's Pool Calculator to get the 17k, but the first couple of times I used the test kit, I was getting higher FC numbers than expected (specifically, the FC was at 10, I added 192oz, which should have brought it up to 15.5, but it was at least 17 when I tested an hour later). I'm still a newb with my test kit, which arrived on Monday, so the discrepancy may be due to my inexperience and not incorrect assumptions about the pool size.
Â
Â
TA: 110
CH: 330/340
CYA: 40
pH: 7.5/7.6
Â
