Joe N
Joe N said:I have a 5yr old gunite pool that has a very light gray stains all over,mostly solid except in spots it looks like somthing spilled on it and cleaned that area.Tried liquid bleach on steps when water was low also tried vitamin c tabs no diffrence vitamin c tabs actually left brown/yellow stains after 1-2 min. of sitting, any one have a suggestions.Thank you.
Joe N
Thanks for the help!!!. I did have a water purafication system that leaked small beeds into the pool prob. the reason for copper stains,I am not using system this year.Joe N said:I have a 5yr old gunite pool that has a very light gray stains all over,mostly solid except in spots it looks like somthing spilled on it and cleaned that area.Tried liquid bleach on steps when water was low also tried vitamin c tabs no diffrence vitamin c tabs actually left brown/yellow stains after 1-2 min. of sitting, any one have a suggestions.Thank you.
Joe N
Do you have any ideas short of acid wash that I can try,
Not without seeing a full set of test results (and NOT with strips!!!!!!!!! Can't stress that enough!)Joe N said:.Do you have any ideas short of acid wash that I can try, Thanks again for your help.
