My htr is about 10 years old and has worked great until now. When I turn it on it cycles as it should (blower comes on, after about 15 sec the gas fires and good heat comes out of the flue and water). It then runs fine for about 5-10 minutes and then abruptly shuts off the blower and the Service and AFS LED's come on. I have replaced the AFS and tubing and also the flue switch but it didn't help. If I recycle the power to the unit and wait about 5 minutes the unit will come back on and does the same thing. The motor sounds strong but I am not sure what it should sound like. It sounds like something is heating up and shutting the unit down and it will restart after cooling down?? AFS and Service LED's are the only lights that come on. Would really appreciate some ideas!!
