Sorry to revive this post from the dead but we just moved two weeks ago and have the same filter and same problem. I swapped the seal with a new one and it still leaks from 3 out of the 7 clamps (they all have that glue substance mentioned above). I took everything back apart and wiped the sealing surface completely clean. It seemed like they had used lube in the past but maybe not on the most recent o-ring changeouts.
Any idea what ended up being the problem? Did it just need some time to properly seat? Did the problem come back?
