I tried an experiment this morning when I needed to add muriatic acid to the pool. I took off the lid to the gallon and screwed on a lid from a Gatorade bottle that I bought once for a sick child. The threads seemed to fit perfectly. This particular lid opens and closes with a turn of the top piece and dispenses liquid through a hole. I really preferred using this to dispense my acid (a job I really dislike but is quite necessary and frequent in my high calcium, SWCG pool). After I had dispensed the proper amount (I use a kitchen scale to weigh it), I removed the lid, rinsed it in the pool, and put the safety lid back on the gallon. What dangers am I likely to run into if I do this? I like this system better than the pour-through-pencil-sized-hole-in-the-seal method I have been using, but I don’t want to be doing something unsafe. Please advise.
Thank you.
Thank you.
